Posted March 26, 2020 I dont know if this is the right category but i am getting a new build and i am really new to building pcs and other the graphics card is second hand so how can i test it without killing it ? what benchmark should i use that will not kill the gpu specs i5 4670k gtx 1060 16gb ram 600w Thermaltake idk if i should use furmark because there is alot of cases of fucking up a gpu so i dont want to take any chances Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2020 heaven Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2020 Author 3 minutes ago, boggy77 said: heaven Will it kill the gpu? How? What should i watchout for and how big is the file to download ? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2020 Just now, YEETMAN said: Will it kill the gpu? only if it's dead already. isn't that the point of the stress test? to figure out whether it works or not? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2020 Author Just now, boggy77 said: only if it's dead already. isn't that the point of the stress test? to figure out whether it works or not? Updated what i said btw how big is the file and how long will it take to download Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2020 4 minutes ago, YEETMAN said: Updated what i said btw how big is the file and how long will it take to download just google it. 250mb https://benchmark.unigine.com/heaven just run it and let it run. monitor temps and frequencies maybe using msi afterburner. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2020 Author Just now, boggy77 said: just google it. 250mb https://benchmark.unigine.com/heaven just run it and let it run. monitor temps and frequencies maybe using msi afterburner. Alright ill check out afterburner which temp should i stop at Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2020 Just now, YEETMAN said: Alright ill check out afterburner which temp should i stop at you don't need to stop it. gpu's have their own safety measures, if it will get too hot, it will throttle (usually around 85C) if you see the gpu going at 85C and staying there, there's something wrong with it. it should stay between 60-75C ideally. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2020 Author 6 minutes ago, boggy77 said: you don't need to stop it. gpu's have their own safety measures, if it will get too hot, it will throttle (usually around 85C) if you see the gpu going at 85C and staying there, there's something wrong with it. it should stay between 60-75C ideally. cool i will use this with after burner for the temp. Afterburner works fine every gpu company right? And i will use gpu z to see if its fake or not Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2020 7 minutes ago, YEETMAN said: Afterburner works fine every gpu company right? yes 7 minutes ago, YEETMAN said: And i will use gpu z to see if its fake or not good strategy Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2020 Author Just now, boggy77 said: yes good strategy Alright wish me luck thx for all the help Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2020 5 minutes ago, YEETMAN said: Alright wish me luck thx for all the help Remember to use heaven in windowed mode, as I have observed that it does not use GPU to the max when suspended. All the best! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2020 Author 33 minutes ago, Hold-Ma-Beer said: Remember to use heaven in windowed mode, as I have observed that it does not use GPU to the max when suspended. All the best! Alright do you think this setup can handle it ? And what score should i be close to where i can say i can buy this 41 minutes ago, boggy77 said: yes good strategy Btw just before i go start dreaming about what i can do with this pc do you think it will handle it ? And what score do you think i should get if the graphics card is all g i want to see what 2 different people say so i know what will happen Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2020 51 minutes ago, YEETMAN said: Alright do you think this setup can handle it ? And what score should i be close to where i can say i can buy this Btw just before i go start dreaming about what i can do with this pc do you think it will handle it ? And what score do you think i should get if the graphics card is all g i want to see what 2 different people say so i know what will happen 2300 +/- 10% on the 1080p extreme test. if it crashes, there's something wrong with the card, any card can "handle it", as the test is design to stress and benchmark all cards. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 26, 2020 50 minutes ago, YEETMAN said: Alright do you think this setup can handle it ? And what score should i be close to where i can say i can buy this Btw just before i go start dreaming about what i can do with this pc do you think it will handle it ? And what score do you think i should get if the graphics card is all g i want to see what 2 different people say so i know what will happen Sorry to disappoint you man, but personally I run an AMD APU and I even haven't stress tested it. I was going to buy a new cooler to replace the stock cooler but this Corona shit happened. So, sorry but I can't help you with this kind of information... But I can tell you, 1060 wouldn't be enough to handle Heaven when you max up the settings.. It's one of the most brutal stress test a GPU can undergo!! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
