Oh okay, because when you do a major OS update the device has to relearn your usage patterns...
Try this: Go to Settings > About phone and then tap "MIUI version" 7 times to unlock Developer options. Go back to settings > Additional settings > Developer options. Scroll down and then turn off "MIUI optimisation". This should help
https://linustechtips.com/topic/1168845-battery-draining-fast/#findComment-13406287
14 minutes ago, EL02 said:
This will reset all of the app permissions. You can adjust them later as they wer
thanks for help but i dont feel like its working its draining fast still now i saw a lot of discussions about that android 10 battery thing maybe they will bring update
https://linustechtips.com/topic/1168845-battery-draining-fast/#findComment-13406366
I hope you have used the phone throughout the day. Was the battery life better this time?
https://linustechtips.com/topic/1168845-battery-draining-fast/#findComment-13409843
