So i was testing my rig and saw that my vsync was turned on , when i turned it off my cpu runs hotter while playing apex legends , max temp is around 86 degrees. So i turned off my CBP and PBO to reach cooler temps. I want to know will it hamper my CPU? Also is there any other way to down my cpu temps while CBP and PBO turned on and vsync off. I am using Ryzen 5 3600 with stock cooler and my mobo is MSI B450m Mortar max. I tried cleaning my pc, opening the side panel and all the other things. My whole pc's age is around 4 months and at first i did not run into issues like this. Also due to the pandemic all the parts shop is closed and i can not go buy a after market cooler. Also i should mention while playing games it always sits at 75-85 degrees Celsius. When i disabled both CBP and PBO the system gets max temp of 73 degrees. Please help me.
https://linustechtips.com/topic/1168799-help-my-cpu-is-overheating/
Vsync limits the framerate, so less frames for the CPU to render.
86c is pretty warm but not too close to the 95c limit.
My advice would be to order a better cooler online, maybe some better case fans. There's not really a way to reduce the heat but keep the performance.
Possibly a small negative offset on the core,  like 0.015 to 0.030v may see a small reduction without performance loss.
What cooler and thermal paste are you using and what case do you have to work with?
Upgrading the cooler and installing good-quality thermal paste should help with lowering the temperatures. Additionally, ensuring that you case is getting proper air-flow is important. Please include a list of fans that you currently have operating in this system?
Hope this information post was helpful  ?,
        @Boomwebsearch
