Help for build pc
Go to solution Solved by Meganter,
If you inted to buy another cooler get the 2600 (the gammaxx 400 is not really good either).
If you don't inted to buy another cooler, the 2600x makes sense.
my build plan more or less like this
Ryzen 5 3500x or maybe 2600x ( i'm planning to get 3600/3600x but because $ increase now it's more expensive. 3500x cost about 200$ , 3600 cost 300$ and 3600x almost 400$ )
Gigabyte B450M Gaming ( before i choose asrock b450m-hdv but someone suggest gigabyte for better vram temp )
Corsair Vengeance LPX DDR4 CMK16GX4M2B3200C16 (2X8GB) can't decide which brand to choose
ZOTAC GAMING GTX 1660 6GB GDDR5 ( not fix ) and still thinking choosing 1060 6gb/1650s/1660/1660s only play @1080p setting high enough, and idk which brand to choose
Seasonic S12II-450 EVO 450W ( not fix ) is this psu good?
Cooler Master Hyper 212 LED
about case for now it's this 2
and i use it only for games
https://linustechtips.com/topic/1168589-help-for-build-pc/
Hello,
3600 is better, 3600x is non sense.
MSI B450 MAX Tomahawk, Gaming plus or A-Pro.
Get the cheapest 3200/3600 you can get.
1660S from any brand with dual/triple fan should be good.
It's obsolete now, get a Corsair CX or CXM.
Not necessary, I'd suggest an Arctic 34 eSport Duo.
19 minutes ago, dlwlrmaa said:
http://cubegaming.id/?p=881
This one because of the front mesh for more airflow :)
https://linustechtips.com/topic/1168589-help-for-build-pc/#findComment-13404033
6 minutes ago, Plouffe said:
Hello,
maybe i can get 3600. if can't because of budget and should i pick 3500x or 2600x ?
for b450 max tomahawk about 200$ , msi b450m gaming plus about 150$ and a-pro 10$ more expensive than gaming plus
cx 450 its good ? i have corsair vx 550w on my old c2d pc. but i don't know if the cable is enough, imo the cable so short
arctic 34 esport duo 54$ and the cooler above cost half price
https://linustechtips.com/topic/1168589-help-for-build-pc/#findComment-13404051
2600 NOT x, 3500 lacks HT and 2600x makes no sense either.
Get the  B450 Gaming Plus ATX not mATX.
CX is good, VX/VS is bad now.
The 212 is not an upgrade compared to the included CPU cooler.
https://linustechtips.com/topic/1168589-help-for-build-pc/#findComment-13404064
okay.
but why 2600x doesn't make sense either ? isn't 2600x clock speed faster a little and a better stock cooler
and i'm not planning on OC
okay i found the motherboard u mean.
what about deepcool gammaxx 400? is that a no too?
https://linustechtips.com/topic/1168589-help-for-build-pc/#findComment-13404079
i see. i put cooler only because i buy 3500x
if i buy 2600x then i won't buy cooler
okay. thanks for the help :)
https://linustechtips.com/topic/1168589-help-for-build-pc/#findComment-13404092
