I've been getting this error when I try to enter some specific websites like wikipedia, I get it on every browser so it's not my browser, also I stop getting this error when I turn on my vpn.
  • Yes, this is only happening on my personal PC, the rest of my devices inside of my network seem to access these websites with no problems.
  • Yes, I've tried restarting my router, didn't work.
  • Yes, I've tried changing my DNS, didn't work.
  • Yes, I've ran a virus scan, nothing came up.
  • Yes, I've tried incognito mode, didn't work.
  • Yes, I've done a network reset several times, didn't work.
The only way I've found to deal with this issue is to use a VPN, which isn't a reliable solution.
I hope someone can help me!
https://linustechtips.com/topic/1168104-err_connection_closed/
That error will show up if for some reason your ISP has blocked a certain website. I would also think it has something to do with ISP because of the VPN fixing the problem. Maybe take a look at that and see if your ISP has those specific sites blocked.
https://linustechtips.com/topic/1168104-err_connection_closed/#findComment-13399927
I don't think so, everything's working fine on my other devices.
https://linustechtips.com/topic/1168104-err_connection_closed/#findComment-13399931
