I have a ryzen 5 2400g and an msi x470 gaming plus. Will a MSI Video Card Radeon RX Vega 56 Air Boost 8G OC go well with it?
https://www.amazon.com/MSI-RX-Vega-Air-Boost/dp/B078DZR5YK/ref=sr_1_1?dchild=1&keywords=vega%2B56&qid=1585001106&refinements=p_89%3AMSI&rnid=2528832011&sr=8-1&th=1
https://linustechtips.com/topic/1168018-graphics-card-help/
The 2400g is a bit faster than a 3770k/4770k so that won’t be a problem specifically.  The issue is power.  Vega56es eat a lot of it.  What kind of PSU do you got?
https://linustechtips.com/topic/1168018-graphics-card-help/#findComment-13399198
Yeah, the V56 can use north of 300 watts peak under load stock.
They could try undervolting if they have a weaker power supply, or maybe go with a 5600 XT.
https://linustechtips.com/topic/1168018-graphics-card-help/#findComment-13399249
