Build planning help
Go to solution Solved by boggy77,
looks good. current ram is ok. enjoy!
Hi there.
Recently I've been planning an upgrade for my pc and if one of you could double check my build and answer questions that'd be great ❤️
So, let's get down to details:
*Thing i'd like to buy*
Ryzen 5 3600
MSI Tomahawk Max B450
(Possibly) Corsair Vengeance RGB 3600
*Things i have now I'd like to keep*
Gigabyte 980Ti (i'll upgrade it later)
NH-U12S cooler (i bought it in 2016, but the nm-am4 mounting kit should solve this problem right?)
G.Skill Ripjaws4 4x4gb 3ghz (F4-3000C15Q-16GRBB)- but ive heard ryzens benefit from higher clock speeds and idk whether the mobo would be fully compatible with them(@3ghz that is)
Corsair RM750
Drives(1 hdd, 1 sata ssd, 1 nvme ssd)
Phanteks Enthoo Pro case
Thanks in advice for any replies, ideas, answering my question or telling my why im wrong xd
Cheers,
NFSU
https://linustechtips.com/topic/1167863-build-planning-help/
