Hello, i recently started playing Doom Eternal, and when i went into the video settings the game told me that my Vram is of 2333 and i can play the game in all ultra settings but the one requiring more Vram of what i have, as a result the game looks awful but runs very good. I searched how to find my Vram, and i found it was higher than 2333, so i was left confused. What can i do? why does the pc tell me i have more Vram than what it will use? Any help i will deeply appreciate as i have very little knowledge of technical pc stuff.
Thank you in advance.
https://linustechtips.com/topic/1167677-vram-not-enough/
What graphics card are you running?
If you would like to find out and let us know, use GPU-Z from here: https://www.techpowerup.com/gpuz/
Click download, run the installer and run the software.
The information in the blue highlighted box is what you need to share with us.screen1-v1584740312603.gif.00b772a0c312dd83ca8348a4b0663a16.gif
SLAMD-XT  Ryzen 2600X 4.125ghz 1.26v~Gigabyte B450 Aorus ELITE~16GB Corsair Vengeance 3000mhz C15~Arcting Cooling Freezer 34 Esports Duo~Gigabyte Aorus RX 5700-XT~CIT chassis~120GB PNY SSD~WD BLUE 3D NAND 1TB SSD M.2~Phobya 120mm G.Silent's~SuperFlower Leadex III GOLD~Razer Basilisk~RedDragon Kumura
https://linustechtips.com/topic/1167677-vram-not-enough/#findComment-13396266
2 minutes ago, Joch said:
It is a Nvidia GeForce GTX 1050, i'm starting to think it won't be able to run it anyways
It should be able to run DOOM Eternal on low to medium settings, give it a try.
https://linustechtips.com/topic/1167677-vram-not-enough/#findComment-13397016
Yeah it can run all settings on ultra but the "Texture pool" one, which even in low exceeds my pc VRam capability, which Doom says to be 2333, but my pc says otherwise. I don't know if this is a reality i have to live with or something i can fix, like a bottleneck or something like that.
https://linustechtips.com/topic/1167677-vram-not-enough/#findComment-13397526
