You mean sets of fans? How many? What are the specs needed? Budget?
Desktop benching:
https://linustechtips.com/topic/1167668-fan-kits/#findComment-13396188
Specs and temps?
Any reason why you're looking for a kit as opposed to standalone fans?
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
https://linustechtips.com/topic/1167668-fan-kits/#findComment-13414477
Hmm, I personally use ThermalTake Pure Plus 12. It comes with 3 fan and a proprietary controller (as their fan uses proprietary USB 2.0 header). You need TT RGB Plus software to control the controller. You need an empty USB 2.0 header from your motherboard (or micro USB) and a Molex type power cable (or Floppy Disk Drive type power).
Fan speed can be adjusted manually or automatically (but it only takes your CPU temperature reading only).
You can customise the LED lighting from the controller. Unfortunately, you can't synchronised your LED lighting with your motherboard.
Further details at their official link:
120mm: https://www.thermaltake.com/pure-plus-12-rgb-radiator-fan-tt-premium-edition-3-fan-pack.html
140mm: https://www.thermaltake.com/pure-plus-14-rgb-radiator-fan-tt-premium-edition-3-fan-pack.html
Note: There is also ARGB variants, and this ARGB fans come with standard PWM cable and ARGB (5V) cable. The ARGB cable can be daisy chain. They also include ARGB controller as well if you don't have a motherboard with ARGB port. You don't need a software for these type.
140mm: https://www.thermaltake.com/pure-14-argb-sync-radiator-fan-tt-premium-edition-3-fan-pack.html
120mm: https://www.thermaltake.com/pure-12-argb-sync-radiator-fan-tt-premium-edition-3-fan-pack.html
I have ASD (Autism Spectrum Disorder). More info: https://en.wikipedia.org/wiki/Autism_spectrum
I apologies if my comments or post offends you in any way, or if my rage got a little too far. I'll try my best to make my post as non-offensive as much as possible.
https://linustechtips.com/topic/1167668-fan-kits/#findComment-13415288
