Hi guys:) after a while questioning and trying to figure out why windos 10 task manager was displaying the wrong ram speeds I figured it out. At first I thought it was windows so i re installed a new version of windows and i tried updating it but that didn’t work, well what solved it for me was updating my motherboard bios
note:( updating mothers boards bios will reset overclockings)
https://linustechtips.com/topic/1167531-task-manager-displaying-wrong-ram-speed/
Hi, welcome to the forum!
Could you provide any actual information about your issue and how you solved it?
For example, the board/RAM/CPU you're using, the actual and reported RAM speeds, and the BIOS versions you went to and from?
This information would be great for other users who are in a similar situation to the one you found yourself in.
Sig under construction.
