I'm trying to find a slim micro atx case that can support a single radiator water cooler and can fit a AMD R7 250. Any suggestions?
Im not exactly grasping what you need. Why cant you use a normal mATX case like the 350d/Arc Mini?
Ryzen 1600@3.8ghz / 16gb 2400mhzASRock B350 ITX / Gigabyte RX 470 4gb / 256gb M.2 / SG13B-Q / Corsair 450w
https://linustechtips.com/topic/116729-slim-case/#findComment-1558980
What size rad? Why water cool with a 250 in a slim case?
https://linustechtips.com/topic/116729-slim-case/#findComment-1558993
I want something that is as slim as a console but thinking of it now i think asking for water cooling is to much
Matx wouldnt be able to fit like that, I'd look at the asrock M8 case. that's as slim as you'll get. Low profile air cooling only, and laptop ram.
I remember Linus doing a video on a slim case, but I cant remember what it was called.
https://linustechtips.com/topic/116729-slim-case/#findComment-1559003
I really like cooler masters micro-atx cases, as they are pretty spacious! I believe they have a micro-atx case that would support that.
I destroy my enemies when I make them my friends.
~Abraham Lincoln
In times when we are on the brink of destruction, war, and loosing ourselves, let's remember a basic fundamental element of love, forgiveness, and understanding; God bless!
https://linustechtips.com/topic/116729-slim-case/#findComment-1559030
thanks I will look in to it.
https://linustechtips.com/topic/116729-slim-case/#findComment-1559035
the rad is a 120mm and i want to water cool the cpu so i can overclock it and because its slim i dont think the airflow will be that good for aircooling.
I wouldn't recommend oc'ing much with a slim case.
https://linustechtips.com/topic/116729-slim-case/#findComment-1559038
I don't know if your going to find a slim micro atx case with water cooling support.  There is the Bitfenix Phenom M that supports water cooling but is a Cube case and not a Slim case.  Also is the R7 250 a low profile card or full size?
https://linustechtips.com/topic/116729-slim-case/#findComment-1559042
it is a full size.
https://linustechtips.com/topic/116729-slim-case/#findComment-1559121
