I'm planning to build a new PC in the near future, my budget is around $1200-1300 but it can be flexible if there are any serious performance gains to be had with a little more investment. It'll mainly be used for gaming, photo/video editing, and likely some VR in the future, but my hardware knowledge is pretty out of date since I haven't build a PC since 2011 so I haven't come to any real decisions other than I'd prefer an NVIDIA GPU.
The budget is for the PC itself and nothing else, I already have the peripherals. If anyone could recommend a build or send me where I should be looking, it'd be appreciated.
https://linustechtips.com/topic/1167046-some-help-with-a-build/
What country?
Desktop benching:
https://linustechtips.com/topic/1167046-some-help-with-a-build/#findComment-13391451
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($298.99 @ Amazon)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard  ($99.99 @ Amazon)
Memory: Team T-FORCE VULCAN Z 32 GB (2 x 16 GB) DDR4-3200 Memory  ($129.99 @ Newegg)
Storage: Western Digital SN750 500 GB M.2-2280 NVME Solid State Drive  ($69.99 @ Newegg)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.98 @ Newegg)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB WINDFORCE OC 3X Video Card  ($489.99 @ Newegg)
Case: Metallic Gear Neo Silent ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: be quiet! Pure Power 11 CM 500 W 80+ Gold Certified Semi-modular ATX Power Supply  ($79.90 @ B&H)
Total: $1263.82
Generated by PCPartPicker 2020-03-21 08:38 EDT-0400
https://linustechtips.com/topic/1167046-some-help-with-a-build/#findComment-13391747
Total: $1263.82
Fantastic, thanks guys. I appreciate the help.
https://linustechtips.com/topic/1167046-some-help-with-a-build/#findComment-13391773
Or if you want , you can get a 2070 super instead and use that 100$ on your storage or something.
https://linustechtips.com/topic/1167046-some-help-with-a-build/#findComment-13392173
