i was thinking about re-purposing my old z68 sli but my buddy offered to buy it. so that sets me up for a new combo. This is the part list i have in mind:
4770k- with more games using more cores, it will be needed for longevity.
mobo- this i dont have really know what to go for but want it quiet, m-atx for sure tho (suggestions?)
ram- some low profile 2x8 gb sticks (suggestions?)
psu- ??? i want it to handle 1x most powerful gpu (780ti classy kp ov/oc) and fit in m-atx case (suggestions?)
videocard- will use my existing 680 ftw 4gb
case: looking for good value and smallish (suggestions?)
optical- best slim, blu ray ready drive (suggestions?)
wifi- htpc is located on the other side of the house so streaming a full 1080p with 5.1 surround gets laggy. i got a asus ac router and thinking about getting asus ac pci-e adaptor
ssd: intel 530 240gb ssd
hard drive: wd black 3 tb
cpu heatsink- this system will be probably be on 24/7, quietness and compatibility with case (suggestions?)
windows??? 8.1 or 7
will be replacing the stock fans with something quieter and low rpm most likely.
i believe i have all the bases covered. any suggestions will be appreciated.
https://linustechtips.com/topic/116681-building-powerful-steamboxhtpc/
dont have a budget but lookin for best value but going for a red theme as well.
We need a rough budget and your location before we star throwing quad 780 ti's and 1tb ssd's at you that vary in price from region to region.
Also, there's little point to getting the 4770k for gaming. You're better off getting a 4670k and upgrading earlier.
Could use one of the new Bitfenix Prodigy in M-ATX Mode- looks and functionality
Main Rig:
AMD FX 8320 @4.5Ghz  8GB Corsair Vengeance LP Blu 1600Mhz Sapphire Vapor X HD 7950 3GB 120GB Samsung 840 Evo  Asus M5A99FX PRO R2.0
Corsair 600T Graphite Corsair H80i Corsair CX600 2x LG 24 inch LED @1080p Logitech G700s CM Quickfire TK (Brown)
Home Server:
A4 6300 @3.7Ghz 5GB Kingston/Crucial DDR3 1600Mhz 1TB WD Green 2TB Seagate Barracuda
500GB WD Blue 2x Gigabit NIC Antec 300 OCZ 500w PSU Gigabyte F2A68HM-HD2 R1.1
For the MATX motherboard probably I would go with either the Gigabyte G1.Sniper M5, Asus Z87M-PLUS or MSI Z87M GAMING <--the Z87M will be perfect
Any dual channel memory kit is fine that is 2x4GB or 2x8GB but games don't need the extra 8GB of ram unless you're running a lot of applications either in the background or at the same time..
If you have a interest in buying a power supply that is efficient and is capable of potentially running 2 fully running graphics card I would advise something like a 700w-800w to give yourself some head room.
I would like to suggest that if you're thinking about grabbing something like a 780 Ti or 780 hold that though, maxwell is coming out soon as we speak so don't buy a graphics card yet even though you'll be still running a GK104 graphics card.
If you're looking for a great performing run of the mill heatsink I would go for the CM Hyper 212 Evo since its fairly cost efficient round about 20-30dollars which you could get a pretty good overclock out of your 4770K, if you want to kick it up a notch using something like a pre-done watercooler from either Corsair (h100i), Cooler Master (Glacier 240L) or Swiftech (H220/H320) will be the cpu heatsink upgrade :D
Noctua is soon releasing their industrial grade black fans so keep an eye out <- they should perform well at a quiet degree of sound. There are other options for quiet fans but I'm super stoked for these ones and the Silent Wing 3 fans from Be Quiet
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
I would opt to go with Windows 8.1 vs 7.
If you want a very nice case any MATX case from any vendor should be fine, I would recommend the FT03 from Silverstone because it fits an MATX motherboard but limits you're cooling potential for you're cpu heatsink by half if you're interested in a h100i or something else, very great build quality since it's silverstone and uses a slim line dvd/cd/blu ray drive
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($219.99 @ Amazon)
CPU Cooler:  Corsair H100i 77.0 CFM Liquid CPU Cooler  ($94.99 @ Amazon)
Motherboard:  Asus MAXIMUS VI GENE Micro ATX LGA1150 Motherboard  ($194.99 @ NCIX US)
Storage:  Crucial M500 240GB 2.5" Solid State Disk  ($122.99 @ NCIX US)
Video Card:  EVGA GeForce GTX 680 2GB Video Card  (Purchased For $0.00)
Wireless Network Adapter:  Asus PCE-AC68 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  ($99.99 @ Newegg)
Power Supply:  Corsair Builder 750W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Newegg)
Optical Drive:  LG UH12NS30 Blu-Ray Reader, DVD/CD Writer  ($49.99 @ Newegg)
Operating System:  Microsoft Windows 8.1 - OEM (64-bit)  ($99.98 @ OutletPC)
Total: $1353.07
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-16 15:46 EST-0500)
So this is basically what you want?
Diamond 5 in League :)
You didn't tell us the budget but here it goes:
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU Cooler:  Noctua NH-L9i 57.5 CFM CPU Cooler  ($45.24 @ NCIX US)
Motherboard:  MSI Z87M-G43 Micro ATX LGA1150 Motherboard  ($94.97 @ OutletPC)
Memory:  Kingston Black 8GB (2 x 4GB) DDR3-1600 Memory  ($74.29 @ Amazon)
Storage:  Intel 530 Series 240GB 2.5" Solid State Disk  ($159.99 @ Amazon)
Storage:  Western Digital BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive  ($194.99 @ Newegg)
Case:  Corsair 350D MicroATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply:  Corsair RM 450W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Newegg)
Optical Drive:  Asus BW-12B1ST/BLK/G/AS Blu-Ray/DVD/CD Writer  ($54.99 @ Microcenter)
Total: $1114.43
(Generated by PCPartPicker 2014-02-16 15:49 EST-0500)
EDIT: Forgot to include the wifi card.
i'm a potato
Total: $1014.44
(Generated by PCPartPicker 2014-02-16 15:47 EST-0500)
He needs a psu that can handle the 780ti kingpin.
Sorry :wacko:
This then:
Power Supply:  Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($129.99 @ Amazon)
Total: $1144.43
(Generated by PCPartPicker 2014-02-16 15:52 EST-0500)
i'm a potato
budget = $1500ish
been googling all of your guys suggestions and here is what i think
4670k
noctua nh-l9i
maximus gene vi
kingston ram 2x4gb
intel 530 240gb
wd black 3 tb
case is still unsure about, prodigy is a maybe but looking for more of a shorter case.
psu seen 7 year warranty on a 760i and leaning towards that
i suppose the case needs to support a slim optical blu ray drive.
any suggestions on good quiest fans?
budget = $1500ish
4670k
noctua nh-l9i
maximus gene vi
kingston ram 2x4gb
intel 530 240gb
wd black 3 tb
Case: Silverstone GDO4
Fans: Noctua NF-F12, obviously :P. Expensive but very good, if you want cheaper fans look at Fractal's line-up.
i'm a potato
budget = $1500ish
4670k
noctua nh-l9i
maximus gene vi
kingston ram 2x4gb
intel 530 240gb
wd black 3 tb
What kind of dollars are you using?
Where are you shopping/located?
