Hey folks
I bought a used graphices card which is asus rx5700xt. When i tried to turn on the pc with this card installed. The pc didn't even went to the bios. The vga led light turned on the motherboard and then it was stuck there.
Can anybody explain whats going on? I updated the motherboard bios tonthe latest version.
The previous gpu was rx580 and it runs okay when i plug it back in.
Other pc components are
*motherboard-msi b450 carbon pro ac
*cpu-ryzen 5 3600x
*ram-corsair lpx 3000mhz
*psu-gigabyte b700h 700w
Thanks in advance.
https://linustechtips.com/topic/1166724-vga-ez-debug-light-on/
1 hour ago, Kawal said:
Hey folks
*cpu-ryzen 5 3600x
Thanks in advance.
Did the seller tell you what that card was used for because it sounds like a bad power delivery form the ocb of the card it self but just to make sure try dduing the GPU then see what happens
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1166724-vga-ez-debug-light-on/#findComment-13388889
What do you mean by dduing the gpu?
https://linustechtips.com/topic/1166724-vga-ez-debug-light-on/#findComment-13390062
Uninstalling all the GPU drivers and downloading a fresh install of the drivers
Build Log:
https://linustechtips.com/topic/1166724-vga-ez-debug-light-on/#findComment-13390068
