Hi everyone,
I'm a novice PC builder and I am looking to build a rig that can handle games at 4K on a 50-65" screen at 60fps, hence the 2080 Ti. I would like to swap out parts as much as possible instead of building a whole new computer as new parts come out, but if you see areas where you could help me cut costs, or could recommend improvements for my needs, please do suggest them. I also can't decide on a case for the build so suggest away. Please remember the prices are in CAD not USD.
https://ca.pcpartpicker.com/list/7znbV7
Thanks!
https://linustechtips.com/topic/1166601-build-help/
9 minutes ago, pcbuilder07 said:
Hi everyone,
Thanks!
here you go
https://linustechtips.com/topic/1166601-build-help/#findComment-13387949
1 hour ago, pcbuilder07 said:
Hi everyone,
Thanks!
do you already have that PSU?
https://linustechtips.com/topic/1166601-build-help/#findComment-13388074
1 hour ago, uTogglin said:
a gaming PC doesn't need a 3900x, much less one that'll run games at 4K considering it'll be GPU bottlenecked anyway.
PSU is mediocre, especially with such a high-end build.
https://linustechtips.com/topic/1166601-build-help/#findComment-13388076
