Need some help quick!
Go to solution Solved by kss306,
A new PSU solved the Problem. I don't know why my pc behaved this way but idc if it works afterwords
Just now, papajo said:
So during all that nothing shut down or froze or anything? also no high temps?
Then what you have to do is just check that all the PSU cables are in place and not slightly off or something.
If everything seems fine then it could be just coincidental that your PC turned off just use it for a couple of days more to avoid the extra expense.
4 minutes ago, kss306 said:
did all the steps and got no error. i bought a new mainboard bc i think that is the broken part
Also reseat (plug off and plug in again) GPU and RAM sticks
Nothing froze and my temp was 60 degrees Celsius at 100% workload and gpu was 70 -80 degrees Celsius at 100%. I don't think it's a coincidence because it crashed like 20 times today and only when I started a game like beatsaber or mw.
So it didnt crash through all that testing but crashes when you play a game?
I am not that familiar with VR unfortunately does it crash when you play non VR games? you use a USB type C port right? maybe some pin got bend or something
Did the VR headset fall down too? could it be that it got damaged somehow?
This happens not only in vr games. In GTA, HL2 and so on. My VR-Headset works without any problem on other pcs.
HL2 is a very light game I cant understand how it didnt crash to furmark+unigine and crashes in HL2...
Do you have windows installed on a small SSD and games on a big capacity HDD? if yes have you used crystaldisk info to check the HDD as well ?
I installed the same game on every drive for testing and it crashed Everytime. I installed my new Mainboard today and it didn't help. I'm guessing the psu is the weak spot then
But I don't understand why it crashes only when I'm playing games and not when I'm benchmarking at 100% load. When I play boneworks it's only at about 30% load. I don't get it
Can I like underclock my CPU and GPU so that it runs at lower voltage? I have a 650 watt psu for 2 years and it never caused any trouble but after the drop it may be damaged.
