Hello, I have a minor problem that my keyboard and mouse does not work when installing Windows 7 on a computer that needs UEFI boot. I have a custom installation and it works via UEFI and I have a keyboard and mouse in USB 2.0. Unfortunately, the motherboard does not have PS2 input. I tried to disable legacy mode USB in Bios / UEFI and still nothing. I am switching back to 7, because 10 of them have annoy me, when a lot of DLL files are missing and even after multiple reinstallations, it throws me 0xc000007b for every 3D application. I tried (NET FW, DX, dll files, ..) but without any positive result, but that's a minor problem. Thanks much for the help. :) Ajrocket
Specs if needed:  Asus Crosshair VI, RTX 2070, R7 2700X, HyperX Predator 2x8 3200MHz @3600MHz
https://linustechtips.com/topic/1166405-keyboard-problem-when-installing-w7/
IIRC Windows 7 doesn't work properly with Ryzen. I had that issue myself, switched to Windows 10.
As a wise master once said,
Put as much effort into your question as you would expect a stranger to add to their answer!
Desktop: AMD Ryzen 5 3800XT | Gigabyte X570 Aorus Ultra | Corsair Vengeance LPX 32 GB 4000Mhz CL18 | MSI RX 5700 XT Gaming X | Two WD Black SN750 1TB NVMe SSD | Corsair AX850 Titanium | Fractal Design Define 7 White, Solid
Laptop: Apple Macbook Pro 16 | i9 9980H | 16 GB RAM |  1TB SSD | AppleCare+ | Space Grey
Peripherals: RAMA U-80 Lake | Logitech MX Master 3 | Kanto YU2 White + Beyerdynamic DT 177X GO
Displays: LG GX 55"| Acer XB273K | Dell Ultrasharp U2720Q | LG 32UN650-W
