I am building my first pc and I would like some advice on storage and GPU. This will be for gaming. I would appreciate any other advice you could give. I wanted to pay about $1,200 or less
So far I am going to be using these parts
Case- 200r (I already got the case)
CPU- I5 3570k
PSU- corsair TX 650
Motherboard- Asrock LGA 1155 extreme 3
Ram- Corsair vengeance 1600MHz
Storage- I do not know what to use
GPU- Not sure
For Storage I wanted to know if I should get an SSD for a boot drive and use a regular hard drive for everything else. What are good drives to do this with? Also I wanted to spend around 300 or less on graphics cards and be Nvidia. I will not be using AA very much and will run at 1920 by 1080. I was thinking of running 650 Ti boost in sli or getting 660 Ti. Any advice would be greatly appreciated.
My rig  case- Graphite 600t white CPU-i5 3570k OC 4.0Ghz RAM- 8gb Vengeance memory HDD-WD Black 1tb PSU-tx650 GPU- MSI 770 gameing edition 2gb , gtx 650 1gb Motherboard- asrock extreme 3 z77 Fan controller- NZXT sentry lx CPU cooler- H60 Peripherals- g300 mouse G630 headset k70 silver cherry mx red switches  my free nas nas Case- Dell something.. Ram- 8 gb ecc ddr 2 CPU - Pentium D 3.0ghz HDD currently 160 gb adding 3tb wd red “Sucking at something is the first step to being sorta good at something” –Jake the Dog
https://linustechtips.com/topic/11663-first-build/
1.  Go with a SSD (Plextor M5 pro xtreme or an Intel SSD) for a boot drive and then a regular hard drive for storage
2.  Generally it will be more worthwhile to get one better card rather than 2 650 ti's.
https://linustechtips.com/topic/11663-first-build/#findComment-124181
Agree. Single 660ti is a good card. Get a good brand like EVGA or Asus. Seagate Barracudas are great and good value for storage.
Current build: Antec P180, Asus P8Z68 Pro, Intel i5-2500k, Asus GTX 570 2GB, Patriot 16GB 1600MHz, Corsair HX 650W.
New build: http://linustechtips.com/main/topic/11270-video-editing-workstation-build/
https://linustechtips.com/topic/11663-first-build/#findComment-125688
I personally would get an SSD for you boot drive and 3.5"'s for storage. I agree with the others, you can't go wrong with a 660Ti! :D
CPU: Intel Core i5 2550K @ 4GHz | Cooler: Gelid Tranquillo Rev. 2 | Mobo: Gigabyte GA-Z68AP-D3
GPU: XFX 1GB HD6850 OC'd | SSD: OCZ Agility 3 60GB | HDD: Samsung 500GB | PSU: Corsair HX520W | Case: Zalman Z11+
https://linustechtips.com/topic/11663-first-build/#findComment-125744
Thanks everyone I will go with a 660 ti. Should I use a WD black drive for my Hard drive
https://linustechtips.com/topic/11663-first-build/#findComment-126216
WD Blacks are awesome. However the Seagate Barracudas are cheaper, kinda the same performance. I haven't tried any of the latest models, so I can't speak from personal experience. Someone else wanna chime in?
https://linustechtips.com/topic/11663-first-build/#findComment-126222
I wouldn't like to say, though I don't think you can go wrong with a WD Black, good choice!
https://linustechtips.com/topic/11663-first-build/#findComment-128575
