Get an NZXT Hue. The adhesive tape sucks (Badly) so to go along with that buy some double sided tape. Otherwise Im loving the one I have. Its bright, has RGB lighting, and tons of modes such as breathing.
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/116615-best-string-led/#findComment-1557412
Bitfenix Alchemy
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/116615-best-string-led/#findComment-1557421
I want to add a good looking blue or red led to my computer but I have no idea which string led is good. My case is a fractal define r4 if that helps. Thanks.
Red
Blue
I use the red ones in 2m length. They are bright enough and not glaring, have adjustable brightness and just work.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/116615-best-string-led/#findComment-1557430
These look good but how bright are they I want a nice bright look.
They are plenty bright on the highest setting. My case is large (haf-x) and it lights up the case, the wall behind it (a foot away from the wall), the floor for 3 feet in front of it and the leds aren't even facing out away from the case. They are facing inwards towards the motherboard. In a smaller case they will appear to be brighter. You wont be disappointed with them.
https://linustechtips.com/topic/116615-best-string-led/#findComment-1557461
Ok ill pick them up from ncix.
https://linustechtips.com/topic/116615-best-string-led/#findComment-1561446
