PC running slow
Solved by JennAndTonic,
4 hours ago, Falcon1986 said:I meant: was an update recently installed? Windows updates are known to cause issues these days.
Also open Task Manager and see if anything is causing high CPU usage.
Actually I think I found the problem: my CPU was stuck at 800 MHz; seems like there's an issue where the z170a throttles CPU usage incorrectly. Turned off thermal throttling and things are looking normal again.
Thanks for your time!
