The screen you see on the 2 photos is the only screen I can see when I turn on my computer. This all originated after I tried to update my bios and then it went into a really low quality screen and downloaded like 1000 things, but thats ok then it just went into that screen which says "Press esc for startup menu", but after I press esc nothing happens, its really annoying I've tried removing the lithium battery and waiting 5 mins, even turned it on without the lithium batter, but nothing happened im still stuck, it'd be appreciated if I could get some advice on how to fix this especially since I'm in quarantine xdxd. Thanks so much
https://linustechtips.com/topic/1166049-help-xd/
