1. I live in the United States and have $1500USD to build a pc, buy a keyboard, and get a monitor. I already have a huge mouse pad and a logitech g pro wireless mouse. I am willing to go a little bit over $1500 if it will get me much better preformance.
2. I plan on using this PC for gaming. I want something futureproof so I dont have to buy a new gpu/cpu in 3 years.
3. With my budget I plan on running 1 144htz monitor at 1440p
4. I do need to purchase a keyboard and 144htz monitor
5. I am upgrading as I am gaming on an ASUS Strix Laptop with a 980M in it. It has been a good laptop but it getting slower and slower month by month.
https://linustechtips.com/topic/1165067-1500-gaming-pc-help/
https://linustechtips.com/topic/1165067-1500-gaming-pc-help/#findComment-13374430
PCPartPicker Part List: https://pcpartpicker.com/list/HDLKNq
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($174.99 @ Amazon)
Motherboard: MSI B450 Gaming Plus MAX ATX AM4 Motherboard  ($104.97 @ Amazon)
Memory: GeIL EVO POTENZA 16 GB (2 x 8 GB) DDR4-3200 Memory  ($63.99 @ Newegg)
Storage: Western Digital Blue 500 GB 2.5" Solid State Drive  ($59.99 @ Newegg)
Video Card: MSI GeForce RTX 2080 8 GB GAMING X TRIO Video Card  ($623.99 @ Best Buy)
Case: Corsair SPEC-05 ATX Mid Tower Case  ($44.99 @ Newegg)
Power Supply: EVGA GD (2019) 600 W 80+ Gold Certified ATX Power Supply  ($67.97 @ Newegg)
Monitor: Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor  ($275.99 @ Best Buy)
Keyboard: Corsair K55 RGB Wired Gaming Keyboard  ($49.88 @ Amazon)
Total: $1466.76
Generated by PCPartPicker 2020-03-15 14:19 EDT-0400
This would be a good list. It has fast ram for Ryzen, and a pretty stylish case and motherboard, if you don't mind black and red.
Trash beauty:
CPU: Xeon X5550
GPU: RX 570 4GB (defective)
SSD: Fattydove Racing 240GB
HDD: WD Blue 320GB
Motherboard: HP Z400
Ram: 6x2GB DDR3 1066
PSU: Corsair TX650
https://linustechtips.com/topic/1165067-1500-gaming-pc-help/#findComment-13374431
7 minutes ago, Slottr said:
which PC is better the other one has a 2080 which seems better but what is the compromise on the other build
https://linustechtips.com/topic/1165067-1500-gaming-pc-help/#findComment-13374462
The motherboard has just a couple less features (which isn't a big deal), the PSU isn't as good, and the case is a little airflow restrictive. However, the overall performance would technically be slightly higher
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1165067-1500-gaming-pc-help/#findComment-13374469
Less storage, slightly "meh"-er power supply. The one I posted has faster memory as well, higher airflow case
The difference between the 2070 super and the 2080 is very small.
The other build isn't bad, but there's those nit-picky things
https://linustechtips.com/topic/1165067-1500-gaming-pc-help/#findComment-13374477
ok also would i need to buy more fans for airflow
https://linustechtips.com/topic/1165067-1500-gaming-pc-help/#findComment-13374483
The case comes with 2 already- so you can just run off those if you want. I might add one more intake though.
https://linustechtips.com/topic/1165067-1500-gaming-pc-help/#findComment-13374488
Both cases come with a very similar fan configuration. I would recommend an extra case fan for either.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1165067-1500-gaming-pc-help/#findComment-13374489
