It appears you have the nvidia DCH driver (installed from windows update/windows store) , uninstall the Nvidia Conrtrol Panel app. Then reinstall the app from Windows Store.
If that does not fix it.
First download the latest driver from nvidia.com/drivers.
Then use DDU to wipe the Nvidia driver.
Install the new driver you downloaded.
gonna try it and see
tried them all but the same error
