Recently i have been using my pc alot to watch tv series on dvd. I have found myself wanting a lcd display like on dedicated dvd playes that tell you how far into the movie/etc you are. Is there anything available like that for a pc? perfhaps something you put in the 3.5" or 5.25" bay?
msi h77ma g43
i5 3470
Coolermaster hyper 212 evo push+pull
Powercolor 7950 pcs+ @1100 mhz core 1400mhz mem
Coolermaster haf 912 advanced 120mm rear, 200mm top 200mm front
Corsair vengeance 2x4gb 1600 MHZ
Windows 8 64bit
Silverstone essentials 500w ST50F-ES
Samsung dvd drive
2x 250GB Hitachi RAID0
Seagate Barracuda 2tb
LG IPS235p
Razer Blackwidow
Razer Deathadder
https://linustechtips.com/topic/116483-front-lcd-panel/
The program you use to play the DVD should have a built in progress bar that tells you how far through your content you are. There's no need for.such a product to exist.
Agreed, that would be the most wasteful thing one could buy and the most nonsensical thing a company could make.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/116483-front-lcd-panel/#findComment-1557052
