Hi all
My specs are:
Ryzen 7 3700x
GTX1660 Super
Asus Prime X570P
16GB Corsair Vengeance 3600mhz (2x 8GB)
500gb sabrent m.2
Corsair CX650M power supply
I have been experiencing frame timing issues in CSGO... particularly at high frame rates. I will have really good FPS 280+ consistently but about every 10 seconds or so my frame timings will shoot from 3-4ms to 50+ms for a brief second, resulting in stutter. When I have enabled V-Sync to limit the FPS to 60, the frame time spikes are less extreme and less frequent (staying at 16.7-16.8ms - occasionally spiking to 25-30), but are occasionally noticeable (not just by looking at the RivaTuner overlay). What can I do to troubleshoot this as in a game like CSGO this can be a really big issue?
Temps, clock speed, fan speed, CPU speed and temps are all normal, and there doesn't appear to be anything unusual happening in HWiNFO or MSI Afterburner monitor corresponding to the frame timing spikes.
Steps I have already tried:
Uninstall and reinstall latest Nvidia drivers.
Switch off DOCP, returning ram to stock 2666mhz and timings.
Tried V-Sync both off and on.
Enabling low latency mode in the nvidia control panel (made it worse)
Unplugging other devices from the extension lead powering my PC.
Tried lowering settings.
Is there any chance that my cheapo extension lead could be causing this, giving uneven power deliver (although I thought there were capacitors in the PSU and MB which were meant to mitigate this?)?
Any help would be greatly appreciated as this is very frustrating as this PC should be able to easily play this game no problem.
Thanks
https://linustechtips.com/topic/1164091-frame-timings-issues/
