Hello everyone!
I'm new to pc building and i've never built one in my life , i've done some research and I have decent ideas for all the parts.
I'm going for a Ryzen 5 3600 but I've read some issues online with the stock cooler people saying they hit around 90° C when they are gaming and the fan becomes really loud which seems really bad , so I was wondering if anyone could help me out with that maybe recommend me a cheap good cpu cooler or if these people were having other issues.
Thanks in advance
https://linustechtips.com/topic/1163864-pc-build-advice/
case and budget?
Desktop benching:
https://linustechtips.com/topic/1163864-pc-build-advice/#findComment-13364415
55 minutes ago, Jurrunio said:
case and budget?
I was thinking about a budget around 900$ to 1000$ , don't wanna go above that cause i only got like 1300$ in total with the peripherals.
For the case I was thinking about Fractal design G , heard some good reviews on it and that it has really decent airflow for the price.
I'm all open for all sorts of recommendations.
https://linustechtips.com/topic/1163864-pc-build-advice/#findComment-13364486
Then there should be enough budget for at least the Hyper 212 Black or Arctic Freezer esports series.. Maybe you can spend more for the Scythe Mugen 5 Rev B
Desktop benching:
https://linustechtips.com/topic/1163864-pc-build-advice/#findComment-13365698
