My new build was working great just minutes before this. I booted up my computer after adding a second  monitor. It worked great, but wasn't booting from my  M.2 Samsung 970 Evo Pro.  I've been booting from this for over a week now. But after I plugged in the second monitor it was booting from my ssd. I restarted and went into bios and now it says no system manager. So I shut the computer down and inspected the M.2 to make sure it was still seated correctly. Looked good, checked my ssd drive while the system was opened, it's good. Reboot, and all li get is the message input not supported. I'm lost.
MSI Tomahawk Max latest BIOS
AMD Ryzen 5 3600
2x8 Corsair vengence 3200 RAM
XFX Radeon 590 GPU
Windows 10 Home latest update as of 6 PM mountain time
https://linustechtips.com/topic/1163824-help/
Monitor specs and where are they plugged in the GPU?
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1163824-help/#findComment-13364091
