Laptop from 2012 not finding a gup after a driver instalation fail
MadSpino_
i7
the gpu is a gt 650m
windows 7
i accidentally installed windows 10 drivers and now its not recognizing a gpu
plz help
Have you tried DDU and reinstalling fresh?
Primary PC:
No i have not tried that
see if it allows you to install the correct drivers
Primary PC:
hella sketchy but it worked tanx XD
