Noise cancellation
Go to solution Solved by ShearMe,
One of the mics is a usb other is a 3.5mm .
Aint gonna work, then. You could edit it in software if you're recording...?
If you want to do it via hardware, you need to connect them out of phase. If you don't know how to do that, tell us what connectors you have on the mics and we can go from there.
https://linustechtips.com/topic/116264-noise-cancellation/#findComment-1554097
https://linustechtips.com/topic/116264-noise-cancellation/#findComment-1555435
You can use deticated noise cancellation software with a single mic. Two that might be worth checking are "Sony Creative Noise Reduction" &  "SoliCall Pro".
Do they take checks?
Lol, SoliCall is only a free trial.
https://linustechtips.com/topic/116264-noise-cancellation/#findComment-1560711
