Hey I need help urgently to format my read only SanDisk micro SD HC I 32 GB
I used regedit storagedevicepolicies and set writeprotect value to zero.
I used disk part to clear the attributes.
I used the sd card formatter from sd association.
I also tried using partition wizard tool to format the partition.
I tried using win32diskimager to write an image file but failed.
I even changed my card readers.
There are no physical switches an card.
Please help :-(
https://linustechtips.com/topic/1162014-please-help-me/
you could try booting up Hirens BootCD and see if it's still write protected. This will bypass all windows policies. If that doesn't work then it has been software locked from something like a phone.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/1162014-please-help-me/#findComment-13348828
You need to find out how the card is write protected.  It used to be done with a small switch that exposed a hole in older designs.  With that one the work around was to place a piece of tape over the hole.  I don’t know the system used to write protect that kind of card but the answer could be in the morphology.  If it’s not it could be a software system.  Write protect is designed to be hard to get around.
https://linustechtips.com/topic/1162014-please-help-me/#findComment-13348929
I checked my card but it's not physically write protected(couldn't find any button, slider or hole).
It has something to do with software....
https://linustechtips.com/topic/1162014-please-help-me/#findComment-13349181
It still shows write protected......
Is there any way to remove this protection??
(Using any other device or OS)
https://linustechtips.com/topic/1162014-please-help-me/#findComment-13349186
It might.  It might also have to do with how the case is shaped.  There will be data.  That’s a a particular kind of card.  I don’t know which kind.  It’s more modern than stuff I know about.  There have been various types of SD cards over the years.  I can see them abandoning actual physical systems because of the ability of users to fairly easily get around them, so you may well be right
It will likely be very specific to that particular type of SD card.
https://linustechtips.com/topic/1162014-please-help-me/#findComment-13349432
MicroSD cards don't have a physical lock switch, unlike full-size SD cards.
Which, on a side note, is not an electrical switch of any kind. It actually relies on the reader to detect the presence/absence of the switch to determine if a card is locked. There are a lot of readers that flat-out ignore it.
If you haven't tried it already, try something like GParted.
If that still shows as read-only, then the card probably set itself as read-only as a fail-safe state. I've heard of cards doing this instead of completely dying so that any data on it is still recoverable. It's probably dead, or at least, not worth resuscitating.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1162014-please-help-me/#findComment-13349648
Well I think I need to get a new card....lol
Thanks for help
https://linustechtips.com/topic/1162014-please-help-me/#findComment-13350223
  Reveal hidden contents
Yep I am getting a new one.
Thanks....
https://linustechtips.com/topic/1162014-please-help-me/#findComment-13350226
Thanks....
Luckily they’re cheap.  That one is pretty slow anyway I think.  I recall a year or more ago the minimum standard was x10 speed and that one is x4
https://linustechtips.com/topic/1162014-please-help-me/#findComment-13350580
