Recently I have had to buy a new Hard Drive and re-install windows. But now, all my desktop gadgets wont work, I drag them from the manager to the desktop and their manager icon sticks to my desktop, and then some of the gadgets wont work.
I can't change the options for any of the gadgets, and the barely work. Any suggestions? They all worked before I had to re-install windows.
-Austin
CPU- i5 4670K CPU Cooler- Corsair H90 MB- MSI Z87 GD-45 RAM- 16gb G.Skill Ripjaws Case- NZXT Phantom 530
PSU- Corsair CX750M Cooler- Corsair H90 Boot Drive- Samsung 850 Evo 250GB
Storage-WD 1TB Blue Storage- Seagate 2TB
https://linustechtips.com/topic/116181-desktop-gadgets-problem/
I'm sorry to let you down but I would advise removing your custom gadgets and disabling them due to vulnerabilities found in them.   Gadgets have been discontinued my Microsoft.  http://windows.microsoft.com/en-nz/windows/gadgets
https://linustechtips.com/topic/116181-desktop-gadgets-problem/#findComment-1553014
Yeah I realize that, but they are just something I like to have. I like the graph offered by the CoreTemp gadget, and the GPU temp gadget helps me monitor it. Any alternatives you can think of?
Thanks,
Austin
https://linustechtips.com/topic/116181-desktop-gadgets-problem/#findComment-1553851
I have seen this also, but I can't seem to give up my gadgets.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
https://linustechtips.com/topic/116181-desktop-gadgets-problem/#findComment-1553888
