Sounds like a bad hard drive head or arm. Can't do anything but RMA it.
I build computers and networks. Fibre Optic is my only dream imaginable.
Studying for my CompTIA A+ and my CCNA, if you have any tips, let me know please!
Main PC: i5 8400, Saphire RX 570 4GB, ASUS TUF Z370 PLUS Gaming, 32GB 3200MHz Patriot Viper RAM, 256GB Kingston SSD, 2TB Seagate Barracuda HDD, 550W Evga PSU.
Home Server: 2x Xeon e5410, 64GB DDR2 ECC
https://linustechtips.com/topic/1161536-need-help/#findComment-13344339
Just now, Jonasen said:
RMA? I dont know very much about computers.. :/
Contact the manufacturer to get it replaced if it's under warranty. If it isn't, then I'd get a new hard drive and copy your data over. This is an HDD and not an SSD, correct?
https://linustechtips.com/topic/1161536-need-help/#findComment-13344345
How long and consistent is the beeping and clicking?
https://linustechtips.com/topic/1161536-need-help/#findComment-13344348
Not 100% sure which one it is, I have an ssd also. im guessing it's the hdd
https://linustechtips.com/topic/1161536-need-help/#findComment-13344354
1 minute ago, Jonasen said:
The beeping only happens on startup the n it stops, and then starts the clicking which goes on forever..
The beeping is your POST startup, which is normal. How many beeps is it, and what motherboard do you have?
The clicking is not though, and I would stop using the hard drive until you get a new one.
https://linustechtips.com/topic/1161536-need-help/#findComment-13344372
There's no moving parts inside an SSD, so that won't be making a clicking noise like a hard drive could.
Easiest way to test if it is the hard drive making the noise is to turn the computer off, open the side panel, and unplug the hard drive. Reboot and see if the noise persists.
https://linustechtips.com/topic/1161536-need-help/#findComment-13344373
Its like three beeps, a little loud. It's a lenovo y720 cube, not sure what motherboard it has
https://linustechtips.com/topic/1161536-need-help/#findComment-13344389
I'll check it out. Thank you
https://linustechtips.com/topic/1161536-need-help/#findComment-13344390
Yea, it's probably the HDD. Take it out and boot your PC without it. Good Luck!
https://linustechtips.com/topic/1161536-need-help/#findComment-13344397
