56 minutes ago, 0x1e said:
@YooBro
It's Ubisoft. A few of their games sync with iCue.
For instance you can have it so red lights can flash with your low health.
Not sure how you disable it. Maybe within uPlay, or icue.
Oh interesting how do I do that?
if you use Aura or RGB Fusion there is a setting in there to sync with games too.
But on the other side, you have 3 problems here.. an R problem, a G problem and a B problem,
Quickest way to solve these is to pull out the contacts on your mainboard that are marked RGB..
:D
