I am using as my "daily driver"  the Razer Deathadder (non elite) for about I think 3 - 4 years now. About 3 weeks ago I wanted to try an MX master 2s because I was thinking about buying one , I connected it and there was no problem for the first 3 minutes , however after a while I saw windows saying : Conifguring your drivers for the Logitech MX master 2s . Anyway , I did not think that it would have an impact on my Razer mouse . Fast forwarding to 1,5 weeks ago and my mouse has a problem with the left click. I need to press it really hard , or I need to press it 2 or 3 times to register the clicks . I dont know if its the driver , if its the age of the mouse , or if its Star Wars Jedi Fallen Order because I was playing and pressing the left click really fast (Sometimes it works fine without any problems and also I have Logitech G Hub installed because of my Logitech G920 wheel)
Thanks for the help!!
ItzUknown
https://linustechtips.com/topic/1161226-mouse-responsivnes-problem/
10 minutes ago, PacketMan said:
If it's only the left click then I'm pretty sure the problem is your mouse, and not your driver or receiver. You can check if there are replacements for the mouse switch so you don't have to throw it away or sell it for a ridiculous price.
Hmm well, I have been thinking about a peripherals upgrade for a while, but I dont know yet. Everything else works perfectly fine on the mouse that's the sad part and also where I live it is kinda difficult to have parts like switches get shipped
