will cpu fan fit?
Go to solution Solved by Fasauceome,
certainly doesn't look much larger than your average tower cooler. since the max height listed for your case is larger than the height of the cooler, I doubt you will have a problem
So i just bought a Cooler CPU ID-Cooling SE-224 RGB 156mm and i just wondered if it fits in my case, my case is the Njoy Vanguard and the max for the cpu height is 160mm so it would be a real  shame if it doesnt.
For comparison the stock amd cooler
88006300_2629605490619508_655899204689854464_n.jpg.8e8a05cfb5403832a16e55a6e6a7ce5a.jpg
💠Case: SilentiumPC Signum SG7V EVO TG ARGB
💠Processor: AMD Ryzen 9 5900x
💠Graphics Card: ASUS TUF RTX 4070 OC
💠RAM: 32 GB Corsair Vengeance RGB PRO @ 3600 CL18
💠CPU Cooler:NZXT KRAKEN Z73
💠Power Supply: Corsair CX750 (750W)
💠HDD: 1 TB WD Blue
💠SSD 1: 240GB Kingston A400
💠SSD 2: 960GB Kingston A400
💠Motherboard: ASUS TUF B450M PLUS GAMING
https://linustechtips.com/topic/1161148-will-cpu-fan-fit/
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1161148-will-cpu-fan-fit/#findComment-13340801
Good news!  The advanced mathematical knowledge I learned in grade school tells me that 156 is less than 160!  So it should be really close but you should be fine.
seriously though 160mm is a very standard case width and that the thing is 156mm implies they designed the thing specifically to fit in 160mm cases.  I strongly suspect you will be fine.  It will go all the way to the other side of the case and there won’t be any extra room but it should fit.
https://linustechtips.com/topic/1161148-will-cpu-fan-fit/#findComment-13340807
6 minutes ago, Fasauceome said:
certainly doesn't look much larger than your average tower cooler. since the max height listed for your case is larger than the height of the cooler, I doubt you will have a problem.
  It's weird cause on the NJOY official site on the case description and specs it doesnt actually say the maximum cpu cooler height.But on numerous sites where they sell this exact case it says 160mm.And if you go on their site on this specific case and you go to gallery you can download a pdf datasheet where it does actually specify like in the picture.my only thing is that i hope it doenst hit the fan above it image.png.47ae5ae903ff97c7e1bce9e0214050a6.png
💠HDD: 1 TB WD Blue
https://linustechtips.com/topic/1161148-will-cpu-fan-fit/#findComment-13340823
Just now, probablydumb said:
my only complain is that i hope it doenst hit the fan above it image.png.47ae5ae903ff97c7e1bce9e0214050a6.png
That’s a harder one.  There are two things big coolers tend to impinge on:  memory and other fans.  Sometimes really tall memory heatsinks can get in the way too.
https://linustechtips.com/topic/1161148-will-cpu-fan-fit/#findComment-13340827
I just hope it doesn't hit the fan above it you know?
💠HDD: 1 TB WD Blue
https://linustechtips.com/topic/1161148-will-cpu-fan-fit/#findComment-13340829
It's gonna be a shame if it hits the rams or something cause i already bought it and it's gonna be a pain refunding it
💠HDD: 1 TB WD Blue
https://linustechtips.com/topic/1161148-will-cpu-fan-fit/#findComment-13340832
If you got low profile ram it probably won’t be.  If it does wind up hitting your ram or fans but only just barely sometimes there are things that can be done.
https://linustechtips.com/topic/1161148-will-cpu-fan-fit/#findComment-13341417
