computer wont start please help!!!
Go to solution Solved by OdiumDolt,
i would try to clear your CMOS first. it sounds like a half dead motherboard, or BIOS. if its BIOS that could be bad, but clearing the CMOS might fix it. If not, your motherboard might have a bios flashback, where you can flash a old bios to see if that would work.
hi i plugged in a second monitor and my computer wont even start i mean it will sometimes but only to the blue screen and with different errors like this one 0xc0000428 and turns off after a couple seconds
and the vga light on the motherboard lights red and sometimes theres not even signal being send to my monitor can somebody help me please
also my rgb on the graphic card doesn't shine on start up i dont know if it means something and i cant remember if it did before
but fans on the card spin
sorry if something doesn't make sense in what i just wrote i just bought that pc for my own money and im just stressed that i broke something
specs
CPU: AMD Ryzen 7 2700x
GPU: GIGABYTE Geforce RTX 2060 SUPER
Motherboard: Aorus B450 PRO
RAM: HyperX Predator RGB 3200MHz x2 8GB
M.2: XPG Spectrix S40G RGB 1TB
be quiet system power 9 600w
i entered bios and after couple second its just freezes and nothing happens
https://linustechtips.com/topic/1161140-computer-wont-start-please-help/
I feel like we aren't getting the whole story. Your system doesn't just fucking die because you plug a monitor in.
Either way, sounds like a GPU issue. Hopefully it's under warranty.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
yeah i know it sounds weird but i dont know wtf happend it is under warranty i will try to send it back
Try a system repair via a window bootable media, looks like you have relatively new hardware. I do not think the monitor broke the card unless something crazy happened like the hdmi cable was forced in the wrong way. Also make sure the graphics card is not loose and is locked into place, check physical layer first.
1 minute ago, jjbeebe said:
Try a system repair via a window bootable media, looks like you have relatively new hardware. I do not think the monitor broke the card unless something crazy happened like the hdmi cable was forced in the wrong way. Also make sure the graphics card is not loose and locked into place, check physical layer first.
i give up man i will send the pc to a professional im scared that i will fuck something up again
It is hard to say with only the information you provided. If there are issues when you are in the bios, that's usually not a good sign. You can try to reset to factory and disable XMP profiles and any overclocking to rule those out as possible issues. Updating the bios can also solve issues, but is not always necessary.
i cant even do anything on the computer cause its freezes after i turn it on
That's what i was just typing lol, use the Clear CMOS jumper and/or what he said, worth a shot before giving up.
what can i do if its the bios buy a new motherboard or?
OMFG MAN I FUCKING LOVE YOU MAN WHATS YOUR PAYPAL I WILL PAY YOU FR THANKS IT WORKED
