USB sound card over a 3m USB extension cable a good idea?
Solved by Derkoli,
10 hours ago, NoTxtWhileDrive said:I'm trying to do some quality-of-life improvements to my couch gaming setup. One of them was placing a usb hub in the desk next to the couch. I bought a cheap usb 2.0 hub and a 3 meter usb extension cable. It's a really big help to my setup. Now I'm asking if I can take it further:
Can I buy a usb sound adapter/card plug it in the hub? What problems with doing this can I expect? Any recommendations for cheap ones?
I used to run a DAC off I think a 6 metre non-powered USB hub with 0 issues. Just get a cable thats rated for 2.0 and you'll be fine
