Xonar DX Sound Level
Solved by Sors,
Thanks. After some research, I think I might get a Fiio E10 and plug the line out from the E10 back to my computer for recording.
Does that makes sense?
Or is there any suggestion you think I should go with?
I'd say I have around $70 to spend on this.
Have you consider something like this? http://www.amazon.com/Koss-155954-VC20-Volume-Control/dp/B00001P4XH
Is just a volume control you plug between the headphones and the soundcard. And is cheap enough to be worth the try.
