Hi guys,
I'm about to build my first "gAmIng" computer.I found all the parts i want but i have no idea which cooler will bw the best.
Specifications :
Lancool II HOTSWAP - CASE
Corsair RM750x- PSU
(Corsair Hydro H100i RGB Platinum SE v2 - CPU COOLING)
M2 NVMe 256gb for windows
2tb ssd for games etc.
Corsair Vengeance RGB 32GB - RAM
Gigabyte GeForce RTX 2080 SUPER
GAMING OC WHITE 8GB GDDR6 - GPU
ASUS Prime X570-Pro, S-AM4 - MOBO
AMD Ryzen 7 3700X - CPU
I looking for white parts mostly, and therefore i want cooler to be white.
As you can see i wrote Corsair H100 on the list, but it is average cooling with high temperatures on AMD
https://linustechtips.com/topic/1160333-white-cooling/
2 hours ago, sobol said:
Hello,
You have that AIO :
https://pcpartpicker.com/product/G6kj4D/enermax-liqtech-ii-360-10217-cfm-liquid-cpu-cooler-elc-ltto360-tbp-w
But you need to put it at the front since it's 360mm.
https://pcpartpicker.com/products/cpu-cooler/#Y=8200000
https://linustechtips.com/topic/1160333-white-cooling/#findComment-13334447
