Curious how pci e lanes breakdown and if I should consider pci 4 for my situation. Currently I have a Samsung 960 pro nvme, GTX 980 (looking at the rtx 3070), and a Asus essense stx pci e soundcard ( paired with a Sennheiser 58x jubilee). I'm looking and AMD and Intel on the lanes if I upgraded to either platform. Any help would be awesome!
https://linustechtips.com/topic/1159807-pci-e-questions/
Right now no pcie 4.0 bandwidth can't be even reached by any gpu not even the upcoming ampere will reach it (most likely) obviously you will need to get  a new platform later which will most likely have pcie 4.0 but your hardware won't be able to take advantage of that bandwidth
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1159807-pci-e-questions/#findComment-13330460
Here is kinda of what I mean. I have a 4970k so currently I'm using a add-on pci card to get the 4x out of the extra 16x lane on my motherboard that over saturates my pci e lanes. Also the sound card I have uses a 1x pci lane. So, I'm trying to math out how many lanes I'll need and if by going Intel I'm over saturating things. Thanks for the reply.
https://linustechtips.com/topic/1159807-pci-e-questions/#findComment-13330789
