2 hours ago, Stockholmes said:
Yeah vertical mounting is a really bad idea for the cards cooling. As the above poster said, don't do it unless you enjoy much higher temps on your card.
Does vertical mounting really affect it that much? I use a Cablemod vertical mount for my gigabyte RX 5700, and I haven't noticed much higher temps unless I use the stock fan curve from AMD (which is a garbage fan curve imo).
The cablemod custom mount moves the GPU nice and far away from the side panel, so it can breathe. The case that OP has would put the GPU right next to the side panel and suffocate it.
Primary PC:
PSU tier list
How many watts do I need?
