so i want to control my phone from my laptop all i want to know is if i can do it using the window's connect application.It cast's my phone screen just fine when i try to control it (the picture) pops up.however i could not find any checkbox as stated anywhere please guid me exact video tutorial would be marvelous but i would really appreciate anyone with the proper steps and images. please help.
https://linustechtips.com/topic/1158822-i-need-help/
Controlling phone is a little pointless. I try that and it not speed up anything really. Except if you want to help someone remotely - then team viewer is nice.
But you can improve your work using few programs
MyPhoneExolorer - for sms, phonebook, remote screen view (and sometimes also control), dialing numbers etc.
YourPhone - for SMS, MMS and also for use your computer for calling (if you have headphones and computer with Bluetooth).
Google Messages - for SMS and MMS as alternative for YourPhone (is even faster, but you must use their SMS application in phone).
Also - Viber and Whatsapp have their desktop/uwp versions that you can link with your phone.
As extra software - Solid Explorer as best android app that supports smb, so you can transfer files to/from your computer easy way.
Try all of them and you'll see it's better and faster than just using phone.
https://linustechtips.com/topic/1158822-i-need-help/#findComment-13324663
