I recently just bought another gtx 970 FTW + and my original card is a gtx 970 ftw, and when I installed the new 970 FTW+ and attached the sli connector, I cant seem to be able to enable "maximize 3D performance. I tried with 2 different sli bridges.
specs: i7 4790k
mobo: asus maximus vii hero
ram: 16gb
power supply; evga 1000 supernova gold
https://linustechtips.com/topic/1158607-sli-help/
why is that a problem? you dont need that...
Desktop benching:
https://linustechtips.com/topic/1158607-sli-help/#findComment-13320057
I thought you're talking about the power plan
anyway this is the problem (screwup?) of EVGA with their 9 series
https://www.evga.com/support/faq/FAQdetails.aspx?faqid=59534
you bought the wrong card
Desktop benching:
https://linustechtips.com/topic/1158607-sli-help/#findComment-13320102
wow thanks, didn't realize that it was that strict with 9 series.
https://linustechtips.com/topic/1158607-sli-help/#findComment-13320152
it's EVGA only, got EVGA into a bit of trouble
Desktop benching:
https://linustechtips.com/topic/1158607-sli-help/#findComment-13320163
5 hours ago, matthaji said:
hey sorry to bother you more, is the chart going left to right, or up and down. like is the highlighted parts all compatible?
it follows the background highlight.
Desktop benching:
https://linustechtips.com/topic/1158607-sli-help/#findComment-13330891
