so i'm about to upgrade my pc with a new mobo, cpu and memory i already have the parts but i dont know what i need to do with my current drivers because is want to keep my windows ssd and i'm concerned that it wont work
so if you guys know how i prepare for the change please tell me thanks
new parts are
- corsair vengeance rgb pro 2x8
-msi b450 tomahawk max
-ryzen 5 2600
i currently have
-asus a68hm-k
-ddr3 hyperx
-A8-7600
https://linustechtips.com/topic/1157460-help-with-upgrade/
2 minutes ago, ILLUMINATY said:
For eg your old mobo driver. Or the drivers for the integrated gpu on the A8-7600. Don`t know for sure but when I swapped my mobo and cpu for new ones I did not uninstall any drivers and it was ok.
oke thank you
https://linustechtips.com/topic/1157460-help-with-upgrade/#findComment-13311263
