are you planning on using an e-gpu box? if so, it should have its own power supply. if not, how were you planning on connecting the GPU to the laptop?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1157435-power-supply/#findComment-13310957
I will be using exp gdc dock version 8.5c mini pci version. I just want to know if the power supply will be ok
https://linustechtips.com/topic/1157435-power-supply/#findComment-13310961
That's group regulated PSU, notice how even total power on two 12V rails ain't even close to total total power rating, and even then it's very unlikely that it's multi-rail, most likely there's some specs fuckery going on.
Short answer - no, don't use it.
Tag or quote me so i see your reply
https://linustechtips.com/topic/1157435-power-supply/#findComment-13310963
Can it power xfx rx 470 or gigabyte gtx 960
https://linustechtips.com/topic/1157435-power-supply/#findComment-13311013
https://linustechtips.com/topic/1157435-power-supply/#findComment-13311021
