Mic Sound issue with audio interface!
Hello people  :)
Everything is working to how I like it and I have set it up to how it's meant to be. However when I'm talking away and stream my mic then gets muted for no odd reasons and I then have to disable and enable the mic under sounds-recording settings. It happen twice in one stream shift.
Audio Interface I'm using is the Behringer UMC22 with audio-technica AT2020 microphone. The audio interface is connected by USB into the desktop. When the mic does go off and people can't hear me from stream/discord/skype the audio interface is powered up and as I talk the green light goes off and on and so from the audio interface it looks all normal, so I don't get to why windows mute itself. When I disable and enable it I hear the windows sound connection goes and the  mic then works as normal and people then can hear.
https://linustechtips.com/topic/1157426-mic-sound-issue-with-audio-interface/
