Is it a must that its a PCI card? There are quite good USB options too.
My Gaming PC:
Inno3D iChill Black - RTX 4080 - +500 Memory, undervolted Core, 2xCorsair QX120 (push) + 2xInno3D 120mm (pull)
AMD Ryzen 7 7800X3D - NZXT x72
G.SKILL Trident Z @6000MHz CL30 - 2x16GB
Asus Strix X670E-E Gaming
1x500GB Samsung 960 Pro (Windows 11 + 10)
1x2TB Kingston KC3000 (Games)
1x1TB WD Blue SN550 (Programs)
1x1TB Samsung 870 EVO (Programs)
Corsair RM-850X + native 12VHPWR-Cable
Lian Li O11 Vision
Alienware 360 HZ QD-OLED AW2725DF, MSI Optix MAG274QRFDE-QD, BenQ ZOWIE XL2720
Logitech G Pro Wireless Superlight 2
Wooting 60HE
Audeze LCD2-C + FiiO K3
Klipsch RP600-M + Klipsch R-120 SW
My Notebook:
MacBook Pro 16 M1 Pro - 16GB
Proxmox-Cluster:
  • Ryzen 9 3950X, Asus Strix X570E F-Gaming, 4x32GB3200MHz ECC, 2x 512GB NVMe ZFS-Mirror (Boot, Testing-VMs + TrueNAS L2ARC), 2x14TB ZFS-Mirror + 1x3TB (TrueNAS-VM), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i7 8700k delidded undervolted, Gigabyte Z390 UD, 4x16GB 3200MHz, 2x 360GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i5 4670, 3x4GB + 1x8GB 1600MHz, 2x 240GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
Proxmox-Backup-Server:
  • i5 4670, 4x4GB 1600MHz, 2x2TB ZFS-Mirror, 2,5G NIC
https://linustechtips.com/topic/1157087-need-bluetooth/#findComment-13308017
10 hours ago, Ls9L said:
so i have a MSI B450M PRO-VDH MAX mobo and the only other pci slot i have open is a PCIx1 slot. any suggestions on a really high quality PCIx1 bluetooth adapter ?
Bluetooth is low-bandwidth and doesn't need PCIe. Even the Intel combo WiFI / Bluetooth M.2 card (which is the defacto standard for laptop wireless) only uses the PCIe for the WiFi side of the card, Bluetooth connects via the USB controller. If you just don't like the idea of a USB device connected to the computer, then you could by an adapter to connect it to one of the MB's internal headers.
https://linustechtips.com/topic/1157087-need-bluetooth/#findComment-13309263
