What cpu do you have?
https://linustechtips.com/topic/1156638-memory-speed/#findComment-13304361
 Considering you seem to have a relatively high end system and you do photoshop and video editing, 32gb seems like the right amount for you. Kingston is a reliable brand and 3200mhz is a fine speed for ram these days. Your chosen ram is a good match for your needs and system.
Hope this helps!
https://linustechtips.com/topic/1156638-memory-speed/#findComment-13304380
Might want more RAM if you edit 4K videos with a lot of effects, and you have been warned about overpriced and subpar boards of Asus.
Desktop benching:
https://linustechtips.com/topic/1156638-memory-speed/#findComment-13304427
