So I've been wanting to overclock my CPU lately and I've been looking around the place for some basic tutorials and things like that, but don't really know what's what. Currently I'm running stock speeds on an 8700K, would it even be beneficial for me to overclock it to see an improvement in gaming? Or would I need to overclock the graphics card as well? Like I mentioned, I'm running an 8700K on an MSI Gaming Pro Carbon MB with a Kraken x62 cooler on it, so I feel like I have plenty of room to overclock (minus the not very decent airflow in the NZXT s340 case I'm using). I don't really want to mess around with the graphics card though as it's a pretty basic air cooled 2080. If you guys know of any good guides or videos that would be greatly appreciated.
My Rig: AMD Ryzen 9 5900X 12-Core 3.7 GHz Socket AM4 105W || NZXT - Kraken X62 Liquid CPU Cooler || MSI MAG X570 TOMAHAWK WIFI AM4 AMD X570 SATA 6Gb/s ATX AMD Motherboard || CORSAIR Vengeance LPX 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3600 (PC4 28800) || SAMSUNG 980 PRO M.2 2280 1TB PCI-Express Gen 4.0 x4 || SAMSUNG 970 EVO PLUS M.2 2280 500GB PCIe Gen 3.0 x4 || Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive || MSI RTX 3080 GAMING Z TRIO 10G LHR || Fractal Design Meshify 2 Black ATX Flexible Dark Tinted Tempered Glass Window || Seasonic FOCUS GX-850, 850W 80+ Gold, Full-Modular || Microsoft - Windows 10 Pro OEM 64-bit || Logitech - G502 Proteus Core Wireless Optical Mouse || Input Club K-Type w/ Ajazz Kiwi Switches
https://linustechtips.com/topic/1156607-overclocking-help/
gonna spend all that extra money on a K SKU CPU and Z series motherboard for the sole feature of overclocking, might as well.
for a basic overclock, all you should really concern yourself with is core voltage and frequency. if you want to start super basic, try to get 4.6 all core at 1.25 volts, and go from there.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1156607-overclocking-help/#findComment-13304042
Enable X.M.P in the bios if you havent already
Set an all core multiplier of 50. (CPU RATIO)
CPU ratio offset when running AVX: 0
CPU ratio mode:fixed mode
CPU ratio apply mode: all core
Set a manual vcore within: 1.25 - 1.35v (if you crash you will need more) start at 1.32
Find the Load line calibration settings under DigitALL power and increase the Load line calibration control level to 5.
https://linustechtips.com/topic/1156607-overclocking-help/#findComment-13304060
37 minutes ago, ShrimpBrime said:
Set All core to 50x
Set v-core to 1.35v (give or take for stability)
Well, since both of you guys mentioned to set the core multiplier to 50, I guess I'll start there and see what happens, thanks!
https://linustechtips.com/topic/1156607-overclocking-help/#findComment-13304123
Can’t say there would be a benefit not knowing what you do with it.
I overclock mine simply for how high the usage is and should have got amd stuff.
I hope it helps compared to running at stock.
I did the same as mentioned. I let the board auto overclock to see where it would go then did a manual of 50x and 1.35.
https://linustechtips.com/topic/1156607-overclocking-help/#findComment-13304218
Almost every 8700k can hit 4.9GHz at 1.35 volts.
This overclock is on the high end, so only do that if youre confident in your cooling.
Also a lot of CPUs need less than that voltage, its just a good starting off point.
And yes, even if you did not overclock your 2080 you will see quite a big difference in 1080p gaming in esport games
My Gaming PC:
Inno3D iChill Black - RTX 4080 - +500 Memory, undervolted Core, 2xCorsair QX120 (push) + 2xInno3D 120mm (pull)
AMD Ryzen 7 7800X3D - NZXT x72
G.SKILL Trident Z @6000MHz CL30 - 2x16GB
Asus Strix X670E-E Gaming
1x500GB Samsung 960 Pro (Windows 11 + 10)
1x2TB Kingston KC3000 (Games)
1x1TB WD Blue SN550 (Programs)
1x1TB Samsung 870 EVO (Programs)
Corsair RM-850X + native 12VHPWR-Cable
Lian Li O11 Vision
Alienware 360 HZ QD-OLED AW2725DF, MSI Optix MAG274QRFDE-QD, BenQ ZOWIE XL2720
Logitech G Pro Wireless Superlight 2
Wooting 60HE
Audeze LCD2-C + FiiO K3
Klipsch RP600-M + Klipsch R-120 SW
My Notebook:
MacBook Pro 16 M1 Pro - 16GB
Proxmox-Cluster:
  • Ryzen 9 3950X, Asus Strix X570E F-Gaming, 4x32GB3200MHz ECC, 2x 512GB NVMe ZFS-Mirror (Boot, Testing-VMs + TrueNAS L2ARC), 2x14TB ZFS-Mirror + 1x3TB (TrueNAS-VM), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i7 8700k delidded undervolted, Gigabyte Z390 UD, 4x16GB 3200MHz, 2x 360GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i5 4670, 3x4GB + 1x8GB 1600MHz, 2x 240GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
Proxmox-Backup-Server:
  • i5 4670, 4x4GB 1600MHz, 2x2TB ZFS-Mirror, 2,5G NIC
https://linustechtips.com/topic/1156607-overclocking-help/#findComment-13305330
