Ram usage depends on what else you have running. You'll be fine with 10GB though.
What other specs do you have?
=Moved to PC Gaming=
https://linustechtips.com/topic/1156564-rust-players-help/#findComment-13303646
My pc is bad
specs are an i5 660 3.33 base 3.60 boost
                     10gb ram
                     amd hd 7730 with 2gb GDDR5 vram directX 11 i think
                     an Hewlett-Packard 304bh
                      Hdd 500gb
I would have a better rig if i was older but i am still in controll of my parrents -_-
suggest my an upgrade, please.
https://linustechtips.com/topic/1156564-rust-players-help/#findComment-13304049
4 minutes ago, Budget gamerXD said:
My pc is bad
                     10gb ram
                      Hdd 500gb
I wouldn't upgrade anything in there, really.
I would pull the hard drive out and buy a cheaper AMD APU system such as this:
And reuse the case you already have.
https://linustechtips.com/topic/1156564-rust-players-help/#findComment-13304075
